Whats the best gas..
Old 05-16-2007, 04:56 PM
stefanb21487's Avatar
Default Whats the best gas..
I have a 2000 accord ex 2.3L vtec, i use shell 89 oct.
is that a good gas cause i want to use the best gas for my car.
also my car rev's high when it starts up like 1,500 and it doesn't drop untill it warms up.
Old 05-16-2007, 07:28 PM
Default RE: Whats the best gas..
in my opinion, the best gas is BP premium....BP premium is clear like water but all Shell gas are yellowish. I would say Shell comes in 2nd after BP then Chevon. Does anyone kno if Hess and Citgo are good or bad??
Old 05-16-2007, 08:13 PM
This has been brought up quite a bit. The search feature works now. Unless your 4 cylinder is having problems anything over 87 octane is a waste of money.
http://www.toptiergas.com/retailers.html
Old 05-16-2007, 09:19 PM
smaglik's Avatar
87 octane
www.toptiergas.com
i prefer shell.
Old 05-17-2007, 01:02 AM
trukid21's Avatar
87 octane is good as long as you get it from a top tier gas pumps like shell,chevron,76,texaco. don't waste your money on higher octane gas unless it requires it(i.e BMW,etc.). and your rpm is normal at 1500 when you start up because its from a cold engine start.as long as it drops down after it warms up then it is ok.
Old 05-17-2007, 09:30 AM
00AccordLX5spd's Avatar
Registered User
You are wasting your money on anything over 87 octanein your 2000 EX. Read the owner's manual. You may actually be getting worse gas mileage by using 89.
Old 05-17-2007, 10:18 AM
Velocifero's Avatar
yeah bottom line: octane is all about compression. doesnt improve fuel economy, doesnt give more power, and it definitely doesnt clean your engine. my H22A takes premium, anything else will run like crap (i know because i ran out of gas once) its compression is 10.6:1, the F23A is 9.3:1. only use that the owner's manual states which is probably regular. i wouldnt waste my money on premium if i didnt have to, believe me..
Old 05-17-2007, 12:28 PM
I use BP Premium, BP Premium Dieseland Conoco Diesel,
I do not do Citigo.
[>:]Citigo is Venezuela's main oil Company.[>:]
Old 05-22-2007, 06:53 PM
RogerB34's Avatar
Buy by octane.
Only difference is additives.
Use octane per Honda specs.
Until last year, HP wasthe result of car companies using Premium gasoline in tests.
Hyundai gotfined for this.
Now if 87 octane is recommended; that is what is used in HP tests.
Some engines such as Toyota Avalon state min octane.
Better performance, MPG,mid grade or better.
And allows them to use Premium for tests (my opinion).
Nice engineering thatenables engine to adjust for lower octane fuel.
Old 05-22-2007, 09:55 PM
hmmm wats the hate for citgo for??? neone like citgo or am i alone lol? i use it! 87octane in my v6 03 coupe
Quick Reply: Whats the best gas..
