trying to replace rear motor mount
Old 03-05-2007, 01:12 PM
bedwards97
Default trying to replace rear motor mount
Took my car into the shop because of a vibration on the steering wheel/dash when stopped at a stoplight/stop sign and the car wasin D4. I suspected it was one of the motor mounts; turns out it was the rear mount gone bad. He ordered a new one from Honda and the bolt holes aren't lining up with the one that's currently on the car. He suspected they just packaged up the wrong part, so he ordered another one. Same thing....right package, but the part still doesn't match. He's calling around and sending pics to other Honda dealers trying to figure out what's goin on. Has anyone heard of this before, and how should he go about replacing the mount? I believe he's saying the old mount has a square bolt pattern, where the new mount has a trapezoidal bolt pattern (or vice versa, I'm not positive on that).
Old 03-05-2007, 08:01 PM
Default RE: trying to replace rear motor mount
He might be ordering the wrong part.... call a honda dealership and ask them for the part number you need and compare that to the one you have.....
Old 03-05-2007, 08:10 PM
hondadude's Avatar
Be sure of the year by usingthe VIN or underhood sticker.
Old 03-05-2007, 08:13 PM
are you sure there isn't a bracket attached to the old one that needs pulled off? I assume the second one down in this link is what you keep recieving...
http://catalog.autohausaz.com/autoha...uo2f55aoynxt45
is this the one you want?
http://www.yjdr.com/motormounts.net/...asp?item=A6592
Old 03-06-2007, 01:33 AM
You can also call your local AutoZone and ask them your question and then get their stock number to see why your isn't matching up...
WheelbrokerAng
Old 03-06-2007, 11:35 AM
bedwards97
sir nasty,
I did verify with a Honda dealer that he is ordering the right partfor the right year model.I alsoforwarded him both links you supplied above. Thanks for the help. I'll let you all know what he finds out.
Old 03-06-2007, 08:53 PM
keep us informed.... this is the first issue like this that I've heard of....
Old 03-14-2007, 03:51 PM
bedwards97
Ok...for anyone interested...I said I'd let you know what happens on this motor mount issue. Someone hadinstalled a k-member and rear motor mount from a 4 cyl. engine onto the car. That's why the mount he kept ordering never matchedup. Anyway...turns out the arm from the motor that attaches to the mount was rubbing against a metal shield atop the mount; thus causing the noise and vibration. He removed the mount, cut off a portion of that shield, and reinstalled. Noise and vibration gone. Saved me $150 by not having to install a new mount.
yankmecrank
03-31-2015 08:51 AM
thetangstr
08-28-2012 11:26 AM
baer77
02-27-2009 03:47 PM
92AccordOwner
01-29-2008 02:43 AM
Markus26
05-17-2006 09:28 PM
Quick Reply: trying to replace rear motor mount
