ABS light stays on !
Old 10-30-2006, 05:32 PM
abhijitgp's Avatar
Default ABS light stays on !
1994 Honda Accord EX, manual transmission, 189000 miles.
Drives well. I was out of country for one month. Had problem shifting into 1st gear initially, but it is solved automatically. BUT... the ABS light STAYS ON ! It is annoying, although the brakes work very well. Do I need to bleed them or refill the brake fluid or anything?
Any inputs appreciated.
Old 10-30-2006, 05:38 PM
Default RE: ABS light stays on !
check the brake fluid level first, if that's fine then take the car out to autozone or somewhere and have them read the code for you (autozone does it for free....) and let us know what error code you're getting....
Old 10-31-2006, 12:42 AM
YeuEmMaiMai's Avatar
most likely it will be a wheel sensor that has quit working.........this is by FAR the most common failure for ABS brakes.....
Old 10-31-2006, 09:13 AM
Chiovnidca's Avatar
ORIGINAL: YeuEmMaiMai
On 94-97 accords the most common reason for the abs light to come on is from low fluid level. A code 1 would be stored.
Old 11-03-2006, 01:56 AM
I have a 1996 Accord 4 Dr Sedan EXL; My ABS light came on it was the modular that need replaced, the part is $1500.00 just for the part, not including labor or tax. I had the dealer discoonect the light it was $80.00
Old 11-03-2006, 11:47 AM
ORIGINAL: MichaelEXL
the dealer disconnected the lite ??? they cannot do it,, it is a safety isuue should you get in an accident they could be liable BIG TIME ..........I cannot believe that a dealership would disconnect the ABS lite ...........
Old 11-03-2006, 02:19 PM
is it leaking? if it is you can reseal it and save yourself a lot of cash........
Old 11-14-2006, 11:52 AM
abhijitgp's Avatar
hi again !
I bled the brakes last weekend with the help of a friend of mine. Then we topped up the brake fluid. The ABS light is still ON... and autozone ppl say that they wont read the code for me since they do it only for check engine light and anything above that....
Please help me !!
Old 11-14-2006, 12:51 PM
Wow, that sucks. Try to find a shop that will read the code for free or for a small fee
Old 11-14-2006, 04:05 PM
if it is a 94 no need for that. all he has to do is jump the sc ( service connector ) rt side dash below glove box 2 wires .. put key on and count the flashes on the instrument cluster ABS LITE
Quick Reply: ABS light stays on !
