Clicking Sound after starting Car. 2004 Honda Accord Coupe
Old 07-19-2013, 02:14 PM
Analyzethis's Avatar
Default Clicking Sound after starting Car. 2004 Honda Accord Coupe
Ok guys, I’ve ran into another issue with my 2004 Honda Accord. Two days ago after starting my car I began hearing a clicking sound while still in park. The sound seems to be coming from the steering wheel dashboard area. After about a minute the clicking stops. I conducted further investigation and found that it also clicks when the key is turned in the on position without the car being actually started. While clicking I felt around underneath the dashboard/steering column towards my feet and felt some vibration there until the clicking stopped. Any ideas on what this could be?
Most of the other issues I’ve had with my car I’ve fixed and now this.... Anyhow I’ve posted a video about it on YouTube a few moments ago under the name Yve King. Initially I couldn't find it, but my friend did after typing “Yve King car starting" in the search area. Any assistance would be greatly appreciated.
Old 07-19-2013, 03:32 PM
It has frequency and similar sound to emergency flashers. Try setting/unsetting the emergency flasher and see if sound is reproduced.
Old 09-06-2013, 03:51 PM
I have an update on this issue. I believe the problem is related to the heating/cooling system. I've come to this conclusion because I notice when I start the car and the air is on, the clicking sound starts, but if when it is switched over to heat, the clicking stops. I also felt around some more as it was clicking and felt the clicking right under the dashboard/steering wheel. I just have no idea what it is that would need to be replaced.
Old 09-06-2013, 04:14 PM
The Air-Mix motor is behind driver's side panel, on the side of the heater core unit. They are known to develop clicking/squeaking sounds due to grease on the internal contacts causing a "hunting" action. Many cars of various brands suffer similar problems. It can be fixed by either replacing air-mix motor or removing motor to clean and relube internals (tricky but google for help).
Try this video and see if sound is similar.
Old 09-07-2013, 05:20 PM
This is the EXACT same noise. It looks like its going to be an expensive fix. Any idea how much something like this will cost?
Old 09-08-2013, 06:17 AM
Are you doing the work or sending it out to be done?
Old 09-09-2013, 10:51 AM
I'm going to send it out for work to be done.
Old 09-09-2013, 11:17 AM
Part is about $140 + shipping. Usually, it cost as much to install as part so around $300 sounds right.
Job does not look to be too tough from shop manual, however manual frequently ignores access issues that add substantially to effort. You can lay under dash on driver's side and observe source of noise and assess how difficult to remove. Three (3) self tapping screws hold servo in place.
Old 09-09-2013, 11:21 AM
If you have Auto Temp Control, try operating in manual mode to see if sound is eliminated. This may be an acceptable "work-around",...if it works. I'm not sure it will.
no.never
08-05-2014 09:02 AM
khaled-hamdy
06-20-2013 10:15 PM
bjr001
03-31-2011 01:28 PM
kpearson10
08-23-2005 02:34 PM
Quick Reply: Clicking Sound after starting Car. 2004 Honda Accord Coupe
