2006 Honda Accord Lock/Unlock Problem
Old 10-20-2012, 11:58 AM
cuso5's Avatar
Question 2006 Honda Accord Lock/Unlock Problem
I would like your advice on what part(s) is needed to correct the following problem. 2006 Honda Accord - remote door lock/unlock problem
From inside vehicle - driver door lock/unlock button works correctly
From outside vehicle with remote - remote correctly locks all 4 doors but only unlocks drivers door
With key in ignition and engine running, the car automatically locks all 4 doors.
Do I need a new actuator for the driver's door?
Many thanks for your guidance.
Old 10-20-2012, 12:53 PM
Ahh....what is not working? I'm slow so you have to spell it out for me, sorry.
Old 10-20-2012, 04:51 PM
The way the remote works to unlock: UNLOCK - Press this button once to unlock the driver’s door. Push it twice to unlock the other doors.
If the other doors unlock after the second press of the unlock button, everything sounds normal.
Attached Thumbnails 2006 Honda Accord Lock/Unlock Problem-unlock.jpg
Old 10-20-2012, 08:17 PM
cuso5's Avatar
Default Reply
The problem is that when you press the remote two times, which normally would unlock all 4 doors, ONLY the driver's door will unlock. The remote DOES properly lock all 4 doors after pressing the remote two times.
In addition, the car locks itself with the key in the ignition as soon as you get out of the car and close the driver's door. If you go out any other door, the car will not lock itself.
Thanks for your insight.
Old 10-20-2012, 09:35 PM
cuso5's Avatar
Smile Problem fixed - 2006 Honda Accord Lock/Unlock Problem
I am not sure why this worked or even why I tried it, but my problem is fixed for now. After reading many posts from other members, I decided to use the key to manually unlock the drivers door and then try to use the remote to unlock the other 3 doors. Fortunately the other 3 doors unlocked and the remote now properly unlocks all 4 doors after pressing the unlock button twice. My assumption is that by using the metal key to unlock the drivers door first cause a "reset" of some kind to allow all 4 doors to sync up when locking and unlocking using the remote.
I hope this information helps other members in this forum.
Old 10-21-2012, 09:21 AM
cuso5's Avatar
Question Not fixed - 2006 Honda Accord - Lock/Unlock Problem
The fix I described did not last overnight. I still do not understand this problem and would appreciate any guidance offered from more experienced members.
2006 Accord 3.0L EX-L
Old 10-22-2012, 06:00 PM
Did you try the same thing again, did it work for a "few"? This may help narrow down the path.
Old 10-24-2012, 01:08 PM
cuso5's Avatar
I did but nothing changed. Do you think the driver door actuator controls whether or not the other 3 doors lock and unlock with the remote?
The lock/unlock control buttons on the inside work perfectly.
Thanks.
Old 10-25-2012, 07:13 PM
Thanks.
Yes, pretty sure there is also a switch in the key lock cyl....sorry too tired to look up....that is why I asked about "re-trying" the key fix.
HateThisHonda
09-19-2013 09:45 AM
sharky06
07-09-2009 01:07 PM
richagem
04-14-2006 05:58 PM
Quick Reply: 2006 Honda Accord Lock/Unlock Problem
