oil light intermitant...
1991 Honda Accord 4 door EX.... my oil light comes on every once in a while...not all the time...and doesn't stay on..flashes for a while..goes off....when I turn off the car...it goes off....oil level is good...oil pressure is good....I was told that these oil sensors are sensative...when the oil is below level....like when the oil pump is pumping oil through the engine ..it reads lower because the oil is being pumped through the engine...so the light goes off....the manual says that it could be a problem with the pressure or the level....both are fine.....anyone?
if you have an aftermarket oil pressure Gage , check the oil pressure sensor mine broke so i have no oil pressure reading right now. so that would be the first place id check. Secondly check the wiring could be grounding somewhere that would cause it to flash.
Hopefully that mechanic tested your oil pressure with an actual pressure gauge. Thats the only real way to tell what your oil pressure is. With that many miles, your oil pump could easily be going out to considering all the sludge thats built up in there from all the dirty oil going into it.
The light for example....didn't come on yesterday at all.....drove it all day....sometimes it comes on sometimes it doesn't flashes for a bit..doesn't matter if its cold or hot high RPMS or low...driving fast or slow..its completely random....I'm gonna replace the oil sensor switch....and get the oil changed in a few weeks....to 5W-30....that seems to be the going oil weight...unless you have some suggestions in oil weight.....Heavier or lighter? I live in Nor California...gets really hot in the summer 100-110....winter is normal...no snow..but cold
oil light hasnt come on for a few days...then it came on randomly for a few min....lets say I replace the sensor switch for the oil light and it keeps doing this.....coming on randomly.....what should be the next step into finding out what the problem is?
