1996 Honda Accord Ex VTEC Engine Problems HELP
Old 04-27-2012, 06:37 AM
EX1996's Avatar
Angry 1996 Honda Accord Ex VTEC Engine Problems HELP
As you can tell, I have a 96 Accord EX with a VTEC (F22B) I believe.
I bought this car a couple months ago with 117,000 miles for only $1,550.
I have tried and tried to figure out what my problem is, but I can't seem to find it. My current assumption is that it could possible be my torque converter (yes I know it's not part of my engine).
The problem that I have is my take-off. If I take off slow driving normal, my car takes off fine and it is still really fast, but if I try to "punch it" on take off, I lose all power and my engine "chuggs". It will also do it in park if I am under the hood and I push the throttle hard.
What makes me think its my torque converter is when the pavement is wet, I can "punch it" and my tires just spin. Honestly, I am clueless but that is my newest idea.
I have changed my spark plugs, wires, TPS, Air Filter and more. Any ideas please let me know cause this is really starting to make me mad.
Old 04-27-2012, 07:29 AM
crispin's Avatar
step 1 is to pull the codes, have you done that yet?
Old 04-27-2012, 02:34 PM
Unhappy 96 Honda accord 2.2 vetch
My check engine light comes on and shuts off only while driving at a steady speed. Scan tool said bad mass air flow (egr) and random misfire 2 and 4. I bought plugs, plug wires, cap and rotor. Made it run better but still has random misfire. I also checked the egr and cleaned the ports. Does anyone know what my next step should take?
Old 04-27-2012, 02:37 PM
Don't tell us what you think the code means, but rather what the code was. I don't think the 94-97 Accords have a Mass Air Flow sensor, so something is wrong w/ your description. Code please, Pnnnn.
If it's an EGR code, we need to know which code to provide guidance.
Old 05-07-2012, 07:48 AM
joec44's Avatar
Off the wall WAG is cat is bad may be falling apart inside and may flow at times at low demand you need to do a back pressure test and go from thare
corey86
05-22-2013 05:54 PM
97hondaaccord
01-09-2013 09:27 AM
bobbyboy545
04-11-2009 11:58 PM
94coupeaccord
02-07-2007 05:01 AM
Quick Reply: 1996 Honda Accord Ex VTEC Engine Problems HELP
