99 accord SURGING IDLE
Old 04-08-2012, 07:17 PM
Deejayphilo's Avatar
Default 99 accord SURGING IDLE
I did every check. Clean the whole intake manifold. Bite the bullet and buy the expensive IACV but still surging idle persist. No check engine light though. Car runs very well in the freeway too....replace TPS too ....anything guys I appreciate I want to tackle this not to skip or ignore the problem.
Old 04-11-2012, 12:45 PM
bairdandrew77's Avatar
Did you spray carb cleaner on the hoses and around the gasket areas for the intake? An air leak is most likely your problem and could've saved you lots of money if that is the cause.
Old 04-11-2012, 03:05 PM
You did EVERY check?
Air in cooling system?
Clean throttle body bore & throttle plate?
Throttle closes COMPLETELY?
Did you set the BASE idle? (or did you simply try to adjust the operating idle)
amcdonal86
05-08-2011 05:27 PM
Honda hobby
09-15-2009 10:28 AM
wjt
07-02-2007 01:15 PM
wanderer63
11-23-2005 01:17 AM
kwiggers
03-16-2005 07:29 PM
Quick Reply: 99 accord SURGING IDLE
