1990 accord shift lock problems
Old 01-20-2012, 02:35 PM
90snowman's Avatar
Default 1990 accord shift lock problems
The key gets stuck in the ignition but when I wiggle my shifter towards Reverse
a "click" will happen by the ignition and then I can remove my key. It is my shifter that is causing the interlock system to engage. Maybe the solenoid or shifter needs adjustment? I have used the search but havent found a specific answer.
Old 01-20-2012, 02:54 PM
It could be the gear position switch or the shift lock pin switch. If you have a volt meter, you may be able to do some tests on those two items. They are open/closed circuits when the shifter is in park.
rydnlow1120
11
11-11-2015 05:29 PM
ICApproval
01-05-2012 11:59 PM
bo bradley
10-03-2011 07:23 PM
tobytigger
10-31-2009 09:57 PM
thunder_x
10-24-2007 10:26 AM
Quick Reply: 1990 accord shift lock problems
