difference between F23A1 & F23A4???
Old 07-19-2011, 01:43 AM
omeezy's Avatar
Default difference between F23A1 & F23A4???
my car is 2001 accord lx 2.3L 4dr sedan vtech
  • when i am looking for parts for my car many times i will encounter the question which engine i have and i do not know what is the difference LX -- L4 - 2.3L 2254cc type F23A4 - MFI GAS SOHC
  • LX -- L4 - 2.3L 2254cc type F23A1 - MFI GAS SOHC
how do i find out exactly which one my car is?
Old 07-19-2011, 02:07 AM
ronjr8102's Avatar
either by ur VIN I think its the 8th or 10th digit (one will b a 1 for ur year so it will be the other one) that will give u the engine code which u can put into google (try "honda vin decoder") and follow links. Also it will b stamped on the engine block somewhere along w/ the serial number.
Old 07-19-2011, 02:30 AM
omeezy's Avatar
i checked out the vin and there is nothing in the vin indicating whether its a F23A1 & F23A4
Old 07-19-2011, 03:55 AM
ronjr8102's Avatar
Found ur answer. I just use google (for everything) I put in "f23a1 f23a4" and it gave me anything w/ those 2 engines in it. I found exactly what u were lookin for on Wikipedia (that & google are probably the 2 best sites).
Under Wikipedia is "Honda F Engines"
F23A1 is 150 hp/152 ft-lb
F23A4 has ULEV certification is 148 hp/150 ft-lb, different exhaust manifold, a 32-bit ECU which uses a wideband O2 sensor when compared to the F23A1.
There is more look it up.
Old 07-19-2011, 06:40 AM
PC96's Avatar
There is a sticker on the timing belt cover with the engine code on it. Check to see if it is still in tact.
Old 07-19-2011, 08:26 AM
omeezy's Avatar
thank you for ur great answers guys
Old 07-22-2011, 02:48 AM
I could be wrong but I read somewhere that the 4 (is the ULEV engine) and the 1 is the (VTEC engine)
ULEV 148hp
VTEC 150hp
hope that helps
Old 07-22-2011, 03:48 AM
ronjr8102's Avatar
Honda-4-Life - they both are VTEC engines just one of those engines is ULEV
Old 07-22-2011, 05:51 AM
piggylover1985's Avatar
ULEV 148hp
VTEC 150hp
hope that helps
They're both V-TEC, but the ULEV engine used a more restricted exhaust manifold with a front wideband O2 sensor so it lost 2hp, but if you use the exhaust manifold from the non ULEV you will get back that 2hp
Old 07-24-2011, 12:23 PM
omeezy's Avatar
does anyone know how much hp to the wheels the f23a1 has?
i know the website says 150hp but im pretty sure thats not the wheels
Quick Reply: difference between F23A1 & F23A4???
