2011 Accord in dash navigation + bluetooth aftermarket
I recently bought a Mobile stations (NAV, GPS, TV, .etc.)
The nav is working (except I don't know how to change that dam language from Chinese to English) but overall things are good.
The only problem I am having is that can't get my audio out.
If I play DVD movie, no sound.
Bluetooth connect fine, my voice goes through mic, other party hear but in my car I have no sound.
I took some pictures, I think I am missing a connection. because thats the only wire left which needs to go somewhere and I have no clue, where to hook that wire up.
The factory radio works good, sound is ok from factory radio as well. but no sound from dvd movie or bluetooth. \
the navigation audio works fine.
Any help really appreciated..
thanks,
thanks,
check these two images as well.
Both of these photos are behind factory stereo and double DIN.
When I try calling from my cell phone which is connected with car bluetooth, I hear the beep comes out from car speakers (its continues beep, like not turn off and keep continues until either the call ends or I turn the factory radio ON.
Factory radio work good and sound is good as well.
I think I am either missing to connect the wire or something like that.
please help.
please help.
sorry man, it's hard to diagnose those units since there is virtually no documentation or support on them. they are buyer beware and most have issues. that unit should cost around $1500-2000 to be done right.
if you are going through the factory amplifier, then it's possible the new HU wire that ties to that is power antenna which turns off the factory amp when not in radio/tuner mode. depends how it's wired, which we don't know.
you need to share install diagrams that came with the unit.
can someone please tell me where is the AUX connector in 2011 accord?
on my first two post is that AUX connector?
if not how is it looks like.
I contacted the vendor and the last 2 wires he said will be connected to AUX connector.
Thanks,
Thanks,
Wiring diagrams are restricted to service manuals that aren't common for consumers. I have the owners manuals for the 2011 but wiring diagrams are tricky.
Beam line?
I'll have to do some research for the wiring configuration of the AUX connector, but what wires do you need to connect? What do they do?
Beam line?
