99 accord 2.3 vtec hitting rev limiter at 4000 rpms?
Old 06-20-2011, 08:50 PM
accord99's Avatar
Default 99 accord 2.3 vtec hitting rev limiter at 4000 rpms?
Why would it be doing this. Exactly 4000 it hits rev limiter! All gears!
Old 06-20-2011, 10:08 PM
Check for stored codes.......any mod's?
Old 06-21-2011, 10:38 PM
accord99's Avatar
Default i checked for codes.
There is p1259-manufacturer controlled fuel and air metering. And. A emissions code. I had no troubles till I removed the vtec spool valve, I believe it called on the back of the head. And cleaned it with Carb cleaner and replaced the gasket/o ring. Has rubber square type seal with screen in bottom of seal. Only thing I have done latley to it. Has never done this before. What does that valve solenoid do? Thanks!!
Old 06-21-2011, 11:08 PM
P1259 is for a vtec malfunction. That valve uses oil pressure to activate the vtec. This is likely causing your car to run poorly. I suggest checking that you plugged it in correctly and also inspect the pins in case you bent one.
What was the other code?
phantomgrey92
06-16-2013 07:14 PM
felpz420
06-14-2011 07:10 PM
vdub90vw
04-01-2011 07:47 PM
Driving me nuts
12-01-2008 07:17 PM
dinzer
10-18-2005 10:27 AM
Quick Reply: 99 accord 2.3 vtec hitting rev limiter at 4000 rpms?
