Ignition key cylinder
Old 12-31-2010, 12:03 AM
tulel1's Avatar
Default Ignition key cylinder
i bought an after market key cylinder to replace my old one that sticks whe the key is taken out. i have made progress in taking out the old cylinder but my issue now is that the pin on the old key currenty in the car would not budge. does anyone have any ideas on how to fix the issue and take the old key out? thank you
Old 12-31-2010, 09:49 AM
What year/trim Accord? Put info in your signature line.
Question is unclear. Is the old key stuck in the old lock cylinder?
Old 12-31-2010, 12:12 PM
tulel1's Avatar
thank you for your quick response.
it is 1990 honda accord Ex. i am trying to remove the original key cylinder that has a pin.It needs to be pricked, pulled out, and replaced with an after market one from auto zone. I have already unscrewed the the nuts an taken out the plastic cover around the steering so this is where am stuck now.
Old 12-31-2010, 12:47 PM
See link techautorepairs.com/ignitionswitch. I think this should cover your question.
Security bolts don't have to be drilled. A sharp punch or cold chisel can be used to strike an edge blow and break them loose. They turn easily once loosened. Same procedure to tighten.
Old 01-01-2011, 07:13 AM
g22cd5's Avatar
Supper Moderator
please post in the right area of the forum....
Old 01-03-2011, 11:28 PM
wings's Avatar
If I understand your question correctly, you need to put the old key in the "I" position to be able to press the pin down to remove the old cylinder. Try it on your new one to see how much more the pin moves when in this position.
To install the new cylinder, put turn the key almost to the "I" position, slide the new cylinder in until it stops, and then simultaneously push it in and turn the key all the way to the "I" position. It should slide right in.
Good luck
csh217
06-17-2014 05:53 PM
corlyf
09-12-2012 11:30 PM
wings
01-03-2011 03:18 PM
brofrank
06-09-2006 09:16 AM
brofrank
02-13-2006 02:58 PM
Quick Reply: Ignition key cylinder
