average fuel consumption
Old 10-18-2010, 06:25 AM
darkgreen18290's Avatar
Unhappy average fuel consumption
For almost a month i owned this car, I calculated the fuel consumption for the first 3 full tanks of gas. 50/50 city hway driving
1st: 430km/ 50 liters
2nd: 451km/ 53 liters
3rd: 434km/ 50 liters
I already manage to change the oil, filter, ATF, PSF, coolant, and set of plugs (NGK). so far I could say everything were good, base on what it looks and sound.
Now I need to know if my Fuel consumption normal? its a lil bit higher for me actually.
In different computation:
8.5 km/liters
11.7 liters/100km
20.2 mpg (if my calculation is correct?)
Old 10-18-2010, 08:28 AM
djalmab's Avatar
Default Mine is about 9.2 KM/L
about the same highway / city profile..
Old 10-18-2010, 12:11 PM
I get about 27-28 mpg w/ my 94 EX on a mix of city/highway probably somewhat more highway than 50/50.
27.5 mpg = 8.55 liters/100km = 11.7 km/liter.
I think your MPG calc must be off as my SI units values match yours, except for MPG. I used Digitial Dutch Unit Converter (http://www.digitaldutch.com/unitconv...onsumption.htm)
Old 10-18-2010, 01:04 PM
g22cd5's Avatar
Supper Moderator
the 20mpg is about right...that’s what the h22 ludes get also...your f20 engine is a destroked h22.
Texas...you have a f22 engine that's why you get good MPG..the OP has a performance honda engine they don’t get as good gas mileage as the economy f22a/f22b engines
Old 10-18-2010, 02:11 PM
There's also imperial gallons vs. USA gallons (about 20% difference). Where's Darkgreen located?
Old 10-19-2010, 02:12 AM
no, mine is: 20.2 mpg = 11.7 liters/100km = 8.5 km\liters
ill be more happy if i can reach 22mpg, will work on it. im thinking to get wheel alignment soon. how about fuel additive bottle that say fuel injector cleaner? is that work for my fuel injectors?
Old 10-19-2010, 07:36 PM
If you'll slow down to 60 mph, increase air pressure to 32 psi, and avoid jackrabbit starts/stops you should get 10% increase easily.
I'm not commenting on your driving habits. I was able to do go from 25 mpg avg to 27-28 w/ slowing down and added air pressure.
Old 10-19-2010, 11:13 PM
thanks actually i increase my tire pressure to 35 front, 33 rear. and im not that aggressive driver. my max speed on hway was about 65-70 mph / 110-120 kph. probably i need to restore the power of this honda. and want to discover more since i got this recently.
Old 10-19-2010, 11:58 PM
Default Hi Jim..answer For You!
I'm not sure of his true location..but when I pinged him
with my pinger he came back with "Ripe"
United Arab Emirates...Dubai
Old 10-20-2010, 02:22 AM
yes, my location is UAE but not in Dubai, it is Abu Dhabi (capital of UAE). Im from Phillipines and working here for about 2 years now.
live2rice
12-17-2009 07:49 AM
AceTheAce
05-08-2009 02:35 PM
itzztrick
03-14-2007 08:53 PM
marlon
01-26-2007 01:33 PM
thunder_x
04-16-2006 09:20 PM
Quick Reply: average fuel consumption
