P2185 - 06 Accord Ex 4 Cylinder
Old 08-04-2010, 10:43 AM
gschmelt's Avatar
Question P2185 - 06 Accord Ex 4 Cylinder
Hello all,
This morning I was driving to a customer and my 06 Accord Ex 4 Cylinder displayed the CEL with code P2185. What causes this code? I'm tied up with work and am about to drive several hundred miles in the next two days and I'm not headed home before then. I can't find much on this code (I read it with my ScanGauge II). What can I do to troubleshoot?
Will I cause damage to my vehicle?
Thanks for the help in advance,
GSchmelt
Old 08-04-2010, 07:48 PM
P2185 = engine coolant temperature sensor #2 high voltage.
That sensor is in the lower tank of the radiator (#10 in the picture). Earlier (2003-2004??) that was a fan switch, but by 2006 that's an actual sensor wired to the ECU.
Dont forget to check for crossed wires or bad connections. But normally that would cause LOW reading, not high.
Not sure what you could damage, but I suspect it's mostly for radiator fan control. Beware of sitting & idling. Otherwise, when the car is actually moving there's plenty of air pushed through the radiator. But keep an eye on the temperature gauge.
Chris Jameson
02-19-2013 06:39 AM
matt2005
09-22-2012 01:45 AM
Ken Boelter
04-13-2010 09:55 PM
STINKA621
03-09-2009 07:53 AM
PJ_STYLES_95AccordEx
10-24-2007 09:58 PM
Quick Reply: P2185 - 06 Accord Ex 4 Cylinder
