dash lights not working
Old 04-27-2010, 08:48 PM
andrew404's Avatar
Default dash lights not working
the dashboard lights on my 95 honda accord stopped working a couple months ago. any idea on how much $$$ it would cost to fix this??
Old 04-28-2010, 12:55 AM
keep_hope_alive's Avatar
all of them at once, or one at a time?
did you verify your fuses are in tact - with a volt meter?
Old 04-28-2010, 08:08 AM
andrew404's Avatar
all of them started to flicker on and off and then they completely turned off. The srs, check engine light, etc all still work though. I haven't done it with a voltmeter but I changed out the fuses for it and it still doesn't work
Old 04-28-2010, 12:42 PM
could be a loose connection at the harness, could be a short, etc. but it's associated with the wiring and fusing - not the lamps themselves. the indicators are usually a separate fuse from the dash illumination which is why they still work.
it could also be a bad dimmer pot - there is usually a **** that allows you to adjust the brighness of your dash lights. if that fails, it can cause this problem also. try playing with that **** and see if you can get them to come back on.
did you install an aftermarket radio at that time?
Old 04-28-2010, 02:06 PM
andrew404's Avatar
yeah i did install a aftermarket radio. can that cause the dash lights to not work?
Old 04-28-2010, 06:46 PM
lol. yes. if you connected the illumination wire incorrectly it would turn off your dash lights.
what did you do with the orange wires in the radio harness? (orange/white and orange/black and maybe just orange)
Old 04-28-2010, 08:48 PM
andrew404's Avatar
well i wasn't the one who installed it best buy did... but the lights still worked for a couple months after it was installed
Old 04-29-2010, 08:16 PM
MinnesotanHonda's Avatar
Well, what if your dash lights didn't work before the aftermarket radio? My dash lights in the middle ( AC controls. etc.) 90 % of the time don't work. But some days they will. for about one drive.
Old 04-29-2010, 09:02 PM
refer to my second reply.
Old 04-30-2010, 11:56 AM
halfpastdead's Avatar
did u try turning the **** yet?
Quick Reply: dash lights not working
