95 Accord wont stay running and probs w/vss
I have a 95 Honda Accord XE with a vtech engine...heavy mileage over 150k. My guages started flickering rpm, speedometer, d4 light blinking. This was several weeks ago.Problem was intermittent for a few days and then just stopped. Now as I was driving my car yesterday it started to do it again and then the car died. Tried to restart a few timesbut it wouldnt turn over. After a few minutes of sitting it finally crasnked up. Later last night when I was on my way to bring my girfriend home, I backed it out of the driveway and the guages started going wacky again and the car died. We tried to restart the car but it woulndt turn over. It would try to start but not crank up almost like it wasnt getting any gas. It didnt act like your typical alternator or starter problem, was still getting power because lights and all worked, no clickling like a bad starter, just simply wont turn over. Does anyone have any idea what mya be causing this? I am pretty sure the speed sensor needs relacing but would not replacing it soon enough cause the car not to start at all?
Bad speed sensor can cause hard shifts and damage trans. Fix soon! Check ebay for inexpensive speed sensor. Easy installation.
Starter not turning could be several things; keyswitch, bad solenoid, or bad battery connection to starter. Given your other problems; intermittent rpm, gauges going out the keyswitch seems likely.
First step is to check battery connections at battery and starter for cleanliness and security.
Check for 12V on the starter signal (to solenoid) wire (small wire that plugs into starter). If you don't get 12V when keyswitch is turned to Start (2-man job), then keyswitch is bad.
If you are getting 12V on starter signal wire and no starter action (no clicking either?), then starter or starter solenoid is dead. A rebuilt or good used starter may be best option. I like used honda starters as they are very durable and most salvage yards will provide a 30 day garuntee. You should be able to get one for < $25. You can order used starter on ebay for a little more.
First of all, find out what code is stored in the engine computer (ECU) and trans computer (TCU). Follow these instructions. Use a thin paperclip or wire to short that connector. http://www.dhost.info/accordinfo/howto/cel.html
Count the check engine light for the ECU codes and count the D4 light for the TCU codes.
People describe how cars start differently.
Here are my terms....
Turning Over = When the starter spins the engine when you turn the key to start.
Fires up = The point where you release the key when you engine has started running without using the starter.
So, is the starter working (turning the engine) or won't it fire up?
On thing that I forgot, the list of codes on that site are for the ECU. Post the TCU codes on here, and we can tell you the source of your problem.
The 94 shop manual can be downloaded from the spoon honda site in the Online Manuals thread in the DIY section. Its free and will help you out immensely.
Your VSS provides a signal for the speedometer, but that doesn't explain the tachometer & other stuff flickering. What about loose wiring in the back of the cluster?
Still, clear up for us whether the starter turns the engine over.
I would still ahve the alternator checked for free at an auto parts store. I've heard flaky alternators can cause gauge problems. I kind of doubt that is your problem but the test is free.
Make sure you check those battery connections
OK so thanks for all the info....the car will fire up but not turn over. I tried following the thread on checking the ECU codes. Followed it to a T and the check engine light and for that matter, no other ldights come on when the ignition is put in the #II position. When I checked under the dash to disconnect the ecu plug, it was already disconnected, dont know how or when it became disconnected. Could that have caused the speedometer, rpm, etc to flicker intermmittently? Still cant figure out why its not turning over. Even after I reconnected the ECU plug,I still have no lights on the dash coming on until I try to fire up the car. Lights work, radio works and all other things electronic are fine. Maybe the car not turning over is a seperate issue unrelated to the gauges not working properly at times? Is it coincendental that the guages dancing around and the car shtting down at the same time? It has been three days now and my regular mechanic must be on vacation because he still hasnt returned my calls. Cant take the car in to have the codes checked because it wont start up now. Help anyone please!!! And thanks so much for your previous posts!!!
Please explain what you mean by that. I don't understand how it can fire up without turning over.
Having the ECU unplugged will cause all kinds of trouble. But now with it plugged back in, tell us in detail how each step works. Answer each question...
1) Key to accessory position. Does the radio work?
2) Key to RUN position. Do the following idiot lights come on for bulb checks?
- check-engine light?
- battery light?
- oil light?
- what others?
3) Key to START position. What exactly happens?
- starter spins (turns over) the engine?
- engine fires up? (can't do this until it first turns over)
- battery light?
- oil light?
- what others?
Sorry I havent responded sooner but we had power outages due to storms....Tried getting the codes but no lights would come on whenI tried getting the codes. I put a perclip into the ECU plug, turned the key to the Number 2 position but no lights came on at all. When I try to start the car, the lights will come on but not until then. Mr. Blake to answer your question...the car will fire up but will not turn over. When I turn the key to the accessory position, the radio does indeed turn on.
When I turn the key to run positon (position II), no dummy lights come on at all. Just found out my mechanic hasnt called me back because he was involved in a motorcyle crash. My car has been sitting for weeks now because I am not sure what direction to go in. Thanks for a ll the posts and the wealth of knowledge.
