How replace rear control arm
Old 03-18-2006, 09:29 PM
meazz1's Avatar
Default How replace rear control arm
I have 94 accord and the mechanic advised that the rear control arm is little bent. I am not sure which one, left or right. I will put that on lift soon.
I bought the car from a salvage auction.
How difficult it is to change the control arm? Also, how much am I looking to spend including parts and labor?
Old 03-18-2006, 10:27 PM
Default RE: How replace rear control arm
if you get it done somewhere...its going to cost more than you want to spend but if you do it yourself its really easy....you just unbolt it! couldnt possibly be easier.....just getting the sway bar hooked back up will prolly be the biggest problem
Old 03-19-2006, 12:28 AM
marbro's Avatar
i think you will want both rear tires removed and the rear up in the air to releave the tention on that sway bar
spudman49
10-13-2008 02:47 PM
mtnbay
07-20-2008 03:22 AM
zero5
06-05-2008 09:39 PM
RoKnAzn
05-21-2007 06:29 PM
meazz1
04-10-2006 06:17 PM
Quick Reply: How replace rear control arm
