Driver side axle replacement tips?
Old 01-16-2009, 01:56 PM
txgunslinger
Default Driver side axle replacement tips?
Sorry if this has been covered, but I can't get the search feature to work at all (no matter what I enter as a search term, nothing is ever found) and the link for the FAQ How to Axle replacement is dead. I'm picking up the driver side axle from autozone after work and hope to have it done by tomorrow. I have a Haynes manual and a good set of tools. Are there any specialty tools I need to get from AZ when I'm there to make the job easier? Is there anything else I should look at replacing while I'm doing the axle?
Thanks,
Thomas
Old 01-16-2009, 01:58 PM
Default RE: Driver side axle replacement tips?
Its a somewhat complicated job. You will need a 36mm socket, ball joint separator, very large screw driver, and a breaker bar and or pipe. You will want to replace the axle seals while you are at it.
Old 01-16-2009, 02:02 PM
nponer's Avatar
Do you have a big enough socket to remove the nut from the rotor that holds the rotor assy connected to the cv axle. Other then that you should be ok, as long as your tire rod does not give you any pain in the a**. Also make sure you have a Big F****ing Hammer just in case.....
Old 01-16-2009, 02:07 PM
txgunslinger
Awesome guys - thx. This forum kicks *** and I only signed up 20 minutes ago!
jza240sx
04-30-2013 04:14 PM
FrankvH
08-22-2010 05:24 PM
toddyfresh
07-06-2008 12:54 AM
toddyfresh
05-16-2008 09:55 PM
nixalot
01-25-2007 02:02 PM
Quick Reply: Driver side axle replacement tips?
