Dome light Problems
Old 12-24-2008, 01:32 PM
cjdm98's Avatar
Default Dome light Problems
Having a problem with my dome light and map light,i was trying to install my ebay led lights,they didn't fit correctly,so i tried to force them in there,..long story short...saw a spark,put my old bulb back in,and now my dome and map lights will not turn on,i already checked fuses,and etc..
Any suggestions?
Old 12-24-2008, 02:10 PM
Default RE: Dome light Problems
Noob. No clue what to tell ya...
Old 12-24-2008, 04:12 PM
cjdm98's Avatar
Ugh..this is pissing me off.
Old 12-29-2008, 04:41 PM
cjdm98's Avatar
Got the dome light working now, But....The light doesnt dim out when i have it on the "door" setting..Normally it dims out then off.Now it stays on...Any Ideas?
Old 12-29-2008, 09:48 PM
Your dome dims out? Mine just turns on and off with the door... I guess I fail and now you fail too.
Old 12-29-2008, 10:01 PM
cjdm98's Avatar
It basically turns off,but now it stays on,even when all doors all closed.[:@]
Old 11-29-2011, 01:26 AM
I know it's an old thread but I've had the same issue.
Doors closed but dome light stays on when in 'middle' position?
Any suggestions?
Thanks;
Old 11-30-2011, 11:50 AM
cutlass327's Avatar
Was this after the conversion to LED? If so, the LED doesn't draw enough power to used the stored energy in the capacitor that causes the fade-out, if they have it designed so that is dependent on the bulb. Otherwise, you may have toasted the transistor the controls the dimming.
LEDs are nice in that they are colorful and cool, but not every incandescent bulb can be replaced by them properly. LEDs don't fade/dim, they are usually on/off.
bdrumm
10-30-2012 10:46 AM
milescwright
05-23-2010 09:46 AM
dan_o_89_rs
01-25-2008 10:29 AM
eckhart
05-08-2006 01:05 PM
Quick Reply: Dome light Problems
