Transmission drain plug size?
Old 11-12-2008, 08:33 PM
jdwilson4's Avatar
Default Transmission drain plug size?
wanted to know the size of the drain plug on transmission or any other suitable fitting for that matter.. trying to get this to fit in the tranny..
http://www.glowshiftdirect.com/threadadapters.aspx
i wanted to run a transmission temp gauge that comes with a 1/8 male fitting.. however im assumeing that 1/8 is way too small for the transmission, so which one of the adapters would work? if any?
is there a better way to do this?
car is 2003 accord v6 AT
Old 11-13-2008, 08:36 AM
falkore24's Avatar
Default RE: Transmission drain plug size?
You might have trouble sealing everything together, but it seems like it would be fine. Once you find out the size, make sure that you have a new crush washer and I'd probably use purple Leak Lock in the sensors threads.
Old 11-13-2008, 09:54 AM
This is all the info I can find on it:
BOLT, PLUG (18MM) No Color
WASHER, DRAIN PLUG (18MM) No Color
It most likely has a 1.5mm thread pitch, and a 12 or 14mm diameter thread.
Fredcheesemonkey
08-04-2013 02:26 PM
MessAround
08-13-2011 09:45 AM
bladeguitar274
09-19-2009 10:03 PM
hondafreak2
12-15-2006 06:43 PM
Quick Reply: Transmission drain plug size?
