95 honda accord vti-s stock tyre pressure? psi?
Old 11-02-2008, 12:18 AM
yiannix's Avatar
Default 95 honda accord vti-s stock tyre pressure? psi?
hi there,
i need to know what pressure my stock tyres should be at?
thanks
Old 11-02-2008, 12:34 AM
Default RE: 95 honda accord vti-s stock tyre pressure? psi?
Open up your car door and look at the tire pressure placard that is posted in there..
Old 11-02-2008, 12:57 AM
yiannix's Avatar
the stickers have come off
Old 11-02-2008, 01:59 PM
Probably somewhere are 32-34 PSI, I don't know how many bar that is....
Old 11-02-2008, 06:21 PM
cjdm98's Avatar
It says it on the tire it self. Ex. (Max psi 40)
Old 11-02-2008, 06:25 PM
Just because they list a maximum, doesn't mean they should be inflated. The lower the PSI, the higher the traction, more tire wear. The higher the PSI, the less traction. Many drag racers run their pressures under or around 20 PSI. Any passenger car I've ever seen, they ask for the pressure to be around 32-36 PSI cold.
Old 11-02-2008, 06:26 PM
cjdm98's Avatar
Good point.And your tire pressure expands as the heat increases.
Old 11-02-2008, 06:37 PM
35psi is the standard.
Old 11-02-2008, 11:09 PM
yiannix's Avatar
omg thanks guys!
christenajenifer
04-21-2010 06:52 AM
runningback23
11-23-2009 01:14 AM
aaron182
11-05-2008 07:56 PM
yiannix
11-02-2008 02:46 PM
tricky
01-24-2006 11:51 AM
Quick Reply: 95 honda accord vti-s stock tyre pressure? psi?
