Engine & Transmission Mounts
Old 10-22-2008, 07:56 AM
19962door's Avatar
Default Engine & Transmission Mounts
I need to replace the rear engine mount and transmission mount on my 1996 Accord.
Here's my questions:
1) How much should each repair cost? I've been told replacing the rear engine mount is a big job - is this because the engine has to held in place when the rear mount is removed?
2) Must I use Honda parts? I have a quote from a Honda dealer of $325 for the rear motor mount.
FYI, when the other two engine mounts were replaced - no lectures, I should have replaced all three at the same time, but $$$$$$ are an issue - the after-market parts caused vibration. When the Honda parts were installed, bingo no vibration. I smell proprietary non-sense here.
Old 10-22-2008, 08:01 AM
Default RE: Engine & Transmission Mounts
1)yeah it is a bigger job, its also just a pain to get to cause there is alot of stuff in the way.
2)that doesnt seem like a terrible price, but Honda dealerships are normally more expensive than independent garages
Aftermarket motor moints cause vibration because they are supposed to, they are meant to be stiffer than stock motor mounts to decrease wheel hop and such and hense cause vibration at idle.
Old 10-22-2008, 08:09 AM
19962door's Avatar
Ok - good to know.
So, here's my next question. Sears quoted me a price, with parts, labor, and tax of $700 for the rear engine mount job.
Is that a reasonable amount, considering about $350 of that is just for the part?
Old 10-22-2008, 08:19 AM
Must be an automatic tranny... With an auto, that rear engine mount is vacuum-operated. It is controlled by the ECU so it makes itself softer when the engine is idling in gear.
So not only is that mount buried &difficult to get at, its also amore complicated part.
Old 10-22-2008, 08:37 AM
http://tasauto.com/Product/Browse.as...;p=1&sz=10
Honda Genuine motor mounts are in there, much cheaper, from our sponsor, T.A.S. Auto. Just buy the parts and ask the shop to install them for you.
Old 10-22-2008, 08:42 AM
19962door's Avatar
Thanks for the information - amazing how even motor mounts become an expensive issue.
BTW, Jim refers to "ECU" control. What does that stand for?
Robert
Old 10-22-2008, 08:44 AM
Engine Control Unit, the computer that controls the injectors and spark, along with a few other things like VTEC.
Old 10-23-2008, 11:52 AM
f allen's Avatar
id shop around, i had a local mech replace my rear mount for 140.00 and i provided the mount , if you shop around you can also save money on the mount. run a search online for honda parts. it is a pretty good job cause everything is in the way but dooable
Frank Allen
mpanelli
11-09-2014 08:39 AM
LordAccord
10-31-2012 12:21 PM
ruski9t
08-11-2008 05:21 PM
BuntinBoy9
02-17-2008 02:51 PM
falkore24
12-03-2007 03:56 PM
Quick Reply: Engine & Transmission Mounts
