how to install brake light switch?
Old 12-21-2007, 08:35 AM
Gomez's Avatar
Default how to install brake light switch?
anyone know how? i can't find anything online.
Old 12-21-2007, 08:58 AM
falkore24's Avatar
Default RE: how to install brake light switch?
It just screws out of the bracket that it's in. Nothing special.
Old 12-21-2007, 10:47 AM
LIKE falkore siad pretty easy, unplug the connector, use a 14 mm open end wrench to loosen the nut, unscrew the brake switch,,,
when reinstalling, make sure that the plunger on the brake switch is all the way in when brake pedal is released
Old 12-21-2007, 11:22 AM
Gomez's Avatar
where is it located? do i have to remove my dash?
Old 12-21-2007, 11:31 AM
ORIGINAL: Gomez
Under the dash, driver's side, at brake pedal bracket,,
No need to remove the dash, it is a 5 minutes job ..very , very easy
get a flash lite, look under the dash and you should see it ..
Old 12-21-2007, 11:49 AM
falkore24's Avatar
the armature of the brake pedal pushes the plunger in when the brakes are not applied. If you push the brake with your hand with your head under the steering wheel, you will see it ..... use a flashlight as DH mentioned above.
rudeg
12-31-2015 07:23 PM
Rabbit
09-14-2012 02:27 PM
victorywhity
03-24-2011 09:37 PM
jdelgado
10-29-2007 09:49 PM
greaser
08-24-2005 12:01 AM
Quick Reply: how to install brake light switch?
