Fuel filter location on a 97 Accord
Old 09-16-2005, 11:39 AM
mojorison_75
Default Fuel filter location on a 97 Accord
Where is the fuel filter located on a 1997 Accord SE? Is it in or outside the tank?
Old 12-04-2005, 02:00 PM
Default RE: Fuel filter location on a 97 Accord
The filter is on the drivers side of the car close to the fire wall. Just follow the hose that goes down from the fuel rail.
Old 12-04-2005, 06:40 PM
under the brake master cylinder ...like ovr said follow the top line /// the trick is to get a 14mm crow foot, a long extension and a rachet ..raise car, loosen the bottom line. lower car, remove the 17mm banjo bolt at the top, undo the lower line from the top u might want to put a pan under filter some fuild will spill. remove the 10mm bolt that attaches the fuel filter bracket and remove the filter/bracket assembly ..it is a bit of a tight fit but it will come out ,, once out remove the 10mm bolt and replace the filter ...............once u go back in,, firtst thing u do is start the bottom line from the top finger loose then put top all together and last thing do not forget to tighten bottom line
ifixm
03-26-2015 06:01 PM
rockhoundrob
04-11-2014 11:41 AM
byebye2u
12-21-2012 04:47 PM
rustyblueyez
07-25-2010 05:16 PM
gary
05-24-2006 12:10 AM
Quick Reply: Fuel filter location on a 97 Accord
