VTEC ENGINE SWAPS
Old 06-07-2007, 10:09 AM
PEEZEE
Default VTEC ENGINE SWAPS
IM NEW TO THE FORUM AND WAS SO IF THERE IS ALREADY A THREAD ABOUT THIS JUST REPLY WITH THE LINK PLS. THANK YOU
IWANT TODO A VTEC MOTOR SWAP WITH MY 91 ACCORD WHAT ENGINES WOULD FIT AND WHAT WOULD BE EASIEST TO DO?
THANK YOU FOR YOUR HELP
Old 06-07-2007, 10:31 AM
legionofone's Avatar
Default RE: VTEC ENGINE SWAPS
Caps lock = cruise control for cool!
Vtec motor swaps arent hard... ECU and engine and wireing harness for ur vtec and ur done... have a good day bye!
Old 06-07-2007, 11:58 AM
00AccordLX5spd's Avatar
Registered User
If you are looking to do a motor swap for more power, drop in an H22. Go to www.cb7tuner.com and look around. That site is dedicated to 90-93 accord owners with H22's. Shadow1992 on here is the resident H22 expert.
Here's a link to another thread on the forum https://www.hondaaccordforum.com/m_5..._/tm.htm#59508
Old 06-07-2007, 01:29 PM
KevinAccord's Avatar
ORIGINAL: 00AccordLX5spd
I agree 100%!!!!!
Old 06-07-2007, 02:28 PM
marbro's Avatar
or you could just use the money you would spend on that and work on a faster f22/23
Old 06-07-2007, 05:09 PM
AccordLX5Spd,
Is there a site like that for 6th gen accord? I'm looking to do the same swap except on my 98 Accord.
Old 06-07-2007, 08:01 PM
Yes, www.6thgenaccord.com
Old 06-08-2007, 08:08 PM
u could, but u'll soon reach a limit and won't b able to keep going. I would choose to go for a H22 engine swap (more mods, parts, andpsi resistance). But, there again, that's my opinion...
Old 06-08-2007, 10:08 PM
BlkCurrantKord's Avatar
ORIGINAL: KevinAccord
The H22 responds pretty well to N/A mods but once you go boost - which isn't a good idea on one with its high compression ratio- the rings are also a major weak point in the motor.
Old 06-09-2007, 02:33 AM
Registered User
ORIGINAL: BlkCurrantKord
I think Shadow1992might disagree. He runs an H22 with 24psi. Well....his is "massively modified" as he says in his signature. So I guess you could be right.
Quick Reply: VTEC ENGINE SWAPS
